These object should have the ability to be intersected and trimmed. The result being trimmed surfaces and finite lines, if trimmed by enough number of objects to make them finite.
Hello - InfinitePlane is only useful inside a command that is asking for a selection and a plane would be a reasonable thing to select - Trim, Split, Boolean*, Intersect… and so on. It is a temporary thing. Does that make sense with what you’re seeing?
No it makes sense to be independent object. Back to my original post. This should be new type.
Working in opposite way, Instead it being drawn to intersect something. My wish is to be infinite planar surface that needs to be intersected with objects in order to create trimmed planar surface. if not enough objects are selected to make it finite it should return false and fail the command.
