Incorrect poche behaviour when walls are in a block
Hi all,
I’m on Windows version 2.12.0.15409
Currently running into this issue w/r/t wall hatches when the walls are in a block.
When the walls are not in a block, this is what it looks like.
Which is about how I would expect walls to show in a plan.
When the walls are in a block, this is what the walls look like.
This is not good! Unfortunately exploding the block is not an option for us. Is there a workaround possible and/or a bugfix in the works?
Bryn
Hello Bryn,
How are you grouping the walls? Are each of them is a separate block? Could you send me the file here or to visualarq@asuni.com?
VisualARQ 2.12.3 is already available, you can update it for free here: https://www.visualarq.com/download/update/
Hey Alfonso,
I’ve updated to 2.12.3 and the error persists.
The walls are in a large block for all existing built works on site.
Here is a file that should help, you reproduce the bug.
Visualarq Bug.3dm (3.7 MB)
Hi @brynmurrell97,
Thanks for the file, but I can reproduce the issue with a simple model on my computer. I’ll try to fix this issue for VisualARQ 2.12.4.
Thanks,
Enric
