So, I’ve been loving VisualARQ and the doors seem to do a fine job cutting every other curtain wall type except for the square panels. For some reason, when I put a door in with this specific curtain wall type, it doesn’t work. I’ve found a workaround solution where you can cut the curtain wall with a bounding box placed around the door, but I want to know if this is a bug or if it can be fixed. Thanks!
Hi Ethan,
That’s an error that has been fixed in the upcoming VisualARQ 2.13 version. I’ll let you know when we publish it.
Hi @Ethan_Cano,
I just want to let you know that we have just released VisualARQ 2.13, which fixes this error you reported about openings in curtain walls.
You have all the information about this new version here: VisualARQ 2 - Version 2.13 released
Enjoy!
