Walls became non-Va Block Instances after most recent update
I’m working on a project with a wall in a block, iterated 3 times.
Since the recent update, the wall registers only as a block instance; it’s Va attributes are gone.
Luckily I just have to replace it with a new wall and hope that works.
Rhino 7
Hi @djhg
Do you mean you have a wall inside a block, which is also inside second block, which is also inside a third block?
Exploding the third block 3 times, should give you in return the VisualARQ wall with its parameters. If this is not working for you, please send a sample file.
