Hi , I notice some weird inconsistency when trying to Union a bunch of Closed Breps. For certain values (nb of units in X and Y direction) it works and I get a single Closed brep. While for others starting values it just doesn’t and the Brep union is incomplete. See attached screenshot. I attach a cleanup GH file with these 3 starting conditions. The initial curve geometry is all similar, just a change in orientation in a plane.
While all geometry before Solid Union is a Closed Brep, could it be that the issues is with starting curve none the less? I tested to bake in Rhino and the Union operation failed as well, like in GH. Same for Mesh Union. Any feedback would be much apricated
Thanks for the fast reply. So should have posted sooner this morning, you could have saved me some hours debugging
The question is why does this behavior occurred in the first place? Is there a common way to prevent this? I see that you check whether splitting occurred with SplitKinkyFaces , why is this?
Rhino automatically “cleans” Breps when they are added in a viewport, but Grasshopper does not. In many cases when working with boolean operations, this is required (and unfortynately there is no native component that does that)
