Hi everybody! ![]()
I created solids and wanted to union, but in result I see open brep ![]()
What did I do wrong? I need to create 1 closed brep
error10-06-23.gh (371.2 KB)
You can boolean union them if you do it one step at a time:
Note that I’ve added Merge components to make the order visible, because this matters with your objects. Same approach works in Rhino.
I notice that the middle piece abuts the one on the left, but overlaps the one on the right - I don’t know if this is deliberate.
Generally Union works best with a slight overlap. You might want to experiment with slight adjustments to the shape of the middle piece to see if you can get a more robust union.
HTH
Jeremy
