Hello, the two “Rectangle” blocks have the same input. The one circled in red outputs to correct positon.
The one in green returns the positons scaled by 2.
This beahaviour persists over “recompute” (F5).
If I hook output of the one in red to intended targets and hit F5, they flip.
As stated above, their unputs are same. Even if there was some loop causing change of input upon recompute, both should show the same values.
