Elefront blocks issues
I am working with Elefront 2019 (I try to install the new version, but i can’t) & Rhino 7, and have found two problems, which I would like you to help me to know why they happen!
One of them is that as soon as my code starts running, the visualization of the blocks is shown with a cross. I can’t figure out why it is. Once I move sliders to change them, it updates and disappears.
Then when I try to bake them, I have to press the bake twice, since the first turns the blocks on and off, and in the second one bakes them in rhino. I would like to know if you could help me to solve this.
I attached some images to show you the issues.
hi @Nayla_Cefarelli
Two things:
  1. this sounds like a block interaction issue with Rhino and GH, can you post the definition? Feel free to PM the the model and definition if you don’t want to publicly post.
  2. Why can’t you install the latest version of eleFront? Are you able to use the Package Manger? If you need the old and new version installed side by side, you can follow the instructions here: Upgrading from Previous Versions - eleFront
It is impossible for me to share the code, because everything is linked to my computer. I think you could help me update the version, to see if I can solve those problems. I have installed from pack manager the update. I closed rhino, reopened it, but I don’t see any change in grasshopper. It also doesn’t let me update components in Grashopper’s Solution. And I see that in the installation screens, elefront appears as something else next to metahopper, shape driver. And if I look for this component that is new (bake to file), it’s not there. I am sending you a screenshot of my special folder, with all this that I already have unlocked. Can I delete the old ones?
