Hi guys, @Joshua_Kennedy ,
I’m here asking if would be possible to make the Gumball CNTRL+ROTATE create a revolved surface instead of an extrusion.
With this feature we’re going to take Shapr3D’s users. ![]()
THANKS!!!
THANKS!!!
Mikko thought the same a while ago:
RH-14888 Control + rotate to revolve
Nice, it’s just 14 years!
Think how much ahead was Mikko!
And today is one of the most advertised features of Shapr3D.
I also have myself a request for the gumball. When I do press an arrow of the Gumball to move or copy things around I often need to move in positive and after that in the negative direction. I often put lets say “10” and move in the positive direction. To move again in the negative direction I need to go back in the arrow value box and put a “-” sign in the front of the existing value to move/copy in the negative direction.
Would be much easier to just press a modifier key to transform the existing typed value into a negative one. This will remove a lot of redundant clicks that I do need to do in a daily basis just to type a negative value. So basically I do wish to press a modifier key and change the existing positive number into a negative one instead of typing myself the “-” sign.
@Cumberland this is already possible with Shift RMB or Shift + Enter
I am still using v7. Thinking to upgrade to v9 when will be available.
