Impossible to grab control point - gumball scale handle blocks it
this is bad, why is scale handle there?
Hide the gumball or toggle its mode
Hi Martin, are there some settings for changing the size and length of the gumball ? Right click on the gumball tab . Would any of those settings give relief to Ivan’s issue?—Mark
The size of gumball handles can be changed in the options.
However I think the scale handle is there because of the bounding box of the object. If the gumball is toggled into another mode, the control point can be clicked
One setting that isn’t in there is GumballScaleMode. If you change it from Absolute to Relative and play with the scale factor, you will not have that problem as the gumball will no longer zoom with view. If somehow a scale handle somehow still does obscure something, all you need to do is zoom a bit.
Seems like “Scale Handle Length” would be an easy fix as well. Thank you for the solve though.—Mark
