Impossible import PDF/Sketchup
For several days I have been having problems. I can no longer import PDF files (even vector files) into Rhino. It tells me that the PDF format is not recognized.
Same if I want to export a 3D model in Sketchup format, it no longer appears in the list of possible export formats.
Any ideas what this is due to?
Can you look in Options > Plug ins and check if the various import/export plugins are checked/enabled? If not try checking them.
Hello, thank you for your reply, but everything seems to be activated.
Also I haven’t installed any add-ons or anything in a while. I just updated Rhino and VA
Maybe try to repair the installation via Windows Programs - right click, choose Modify>Repair.
Indeed, I hadn’t thought of that. Well another problem, when I try to “repair” I get this error message: " rhino.msi:-2147023258"
I wanted to try a reinstallation, and it was also impossible.
>>>> C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253.log
[14C0:6650][2025-03-05T07:32:53]i001: Burn v3.11.100.14911, Windows v10.0 (Build 26100: Service Pack 0), path: C:\Users\UTILIS~1\AppData\Local\Temp\{F22384DF-8C57-4575-97C4-65A6EF317EDD}\.cr\rhino_fr-fr_8.16.25042.13001.exe
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'BundleVersion' to value '8.16.25042.13001'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'CUSTOMER_NAME' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'COMPANY_NAME' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'INSTALLDIR' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'LICENSE_METHOD' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Initializing hidden variable 'LICENSE_KEY'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing hidden variable 'LICENSE_VALIDATION_CODE'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'ZOO_SERVER' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'DISABLE_INTERNET_ACCESS' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'ENABLE_AUTOMATIC_UPDATES' to value '1'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'SEND_STATISTICS' to value '1'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'RegistryRoot' to value 'Software\McNeel\Rhinoceros\8.0\Install'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'FolderName' to value 'Rhino 8'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'IgnoreFolderName' to value 'Rhino 8 WIP'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'CheckNETRuntime_Framework' to value 'Microsoft.WindowsDesktop.App'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'CheckNETRuntime_Version' to value '7.0.0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'CheckNETRuntime_RollForwardPolicy' to value 'LatestPatch'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing string variable 'CheckNETRuntime_Result' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_EN' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_FR' to value '1'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_IT' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_DE' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_ES' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_KO' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_JA' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_TW' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_CN' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_PL' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_CS' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_PT' to value '0'
[14C0:6650][2025-03-05T07:32:53]i000: Initializing numeric variable 'INSTALL_RU' to value '0'
[14C0:6650][2025-03-05T07:32:53]i009: Command Line: '-burn.clean.room=C:\Users\Utilisateur\Downloads\rhino_fr-fr_8.16.25042.13001.exe -burn.filehandle.attached=800 -burn.filehandle.self=616'
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Utilisateur\Downloads\rhino_fr-fr_8.16.25042.13001.exe'
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Utilisateur\Downloads\'
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253.log'
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'WixBundleManufacturer' to value 'Robert McNeel & Associates'
[14C0:6650][2025-03-05T07:32:53]i100: Detect begin, 19 packages
[14C0:2DF0][2025-03-05T07:32:53]i000: OnInitializeModify
[14C0:2DF0][2025-03-05T07:32:53]i000: PrivateDetect Begin
[14C0:2DF0][2025-03-05T07:32:53]i000: Failed to open license file: 'C:\ProgramData\McNeel\Rhinoceros\6.0\License Manager\Licenses\55500d41-3a41-4474-99b3-684032a4f4df.lic'
[14C0:2DF0][2025-03-05T07:32:53]i000: PrivateDetectNetCoreRuntime Begin
[14C0:2DF0][2025-03-05T07:32:53]i000: netcorecheck_path: C:\Users\UTILIS~1\AppData\Local\Temp\{B135445C-C734-423C-BC6C-EE429BF6074D}\.ba\helpers\NetCoreCheck.exe
[14C0:2DF0][2025-03-05T07:32:53]i000: CheckNETRuntime_Framework: Microsoft.WindowsDesktop.App
[14C0:2DF0][2025-03-05T07:32:53]i000: CheckNETRuntime_Version: 7.0.0
[14C0:2DF0][2025-03-05T07:32:53]i000: CheckNETRuntime_RollForwardPolicy: LatestPatch
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting string variable 'CheckNETRuntime_Result' to value '0'
[14C0:2DF0][2025-03-05T07:32:53]i000: PrivateDetectNetCoreRuntime End
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting hidden variable 'LICENSE_KEY'
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting string variable 'CUSTOMER_NAME' to value ''
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting string variable 'COMPANY_NAME' to value ''
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting string variable 'INSTALLDIR' to value 'C:\Program Files\Rhino 8\'
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'SEND_STATISTICS' to value 1
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'ENABLE_AUTOMATIC_UPDATES' to value 1
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'DISABLE_INTERNET_ACCESS' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_EN' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_FR' to value 1
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_IT' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_DE' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_ES' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_KO' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_JA' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_TW' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_CN' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_PL' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_CS' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_PT' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: Setting numeric variable 'INSTALL_RU' to value 0
[14C0:2DF0][2025-03-05T07:32:53]i000: GetSystemDefaultLangID() returned 1036
[14C0:2DF0][2025-03-05T07:32:53]i000: GetUserDefaultLangID() returned 1036
[14C0:2DF0][2025-03-05T07:32:53]i000: GetOsLanguage() returned fr
[14C0:2DF0][2025-03-05T07:32:53]i000: version_NT64 = 10.0.0.0; service_pack =
[14C0:2DF0][2025-03-05T07:32:53]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[14C0:2DF0][2025-03-05T07:32:53]i000: ver_64 >= ver_win_10
[14C0:2DF0][2025-03-05T07:32:53]i000: Showing UI from C:\Users\UTILIS~1\AppData\Local\Temp\{B135445C-C734-423C-BC6C-EE429BF6074D}\.ba\fr\modify.htm
[14C0:6650][2025-03-05T07:32:53]i000: Setting version variable 'WUAUENG_FILEVERSION' to value '1309.2501.23012.0'
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'ReadDisableInternetAccess' evaluates to false.
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'VC2010_exists' to value 1
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'NOT INSTALLDIR' evaluates to false.
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'VC2015_build' to value '34433'
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'VC2013_exists' to value 1
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'MSWebView2_Standalone_version' to value '133.0.3065.92'
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'ReadDisableInternetAccess' to value 1
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'NOT ZOO_SERVER' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i000: Registry key not found. Key = 'SOFTWARE\McNeel\Rhinoceros\6.0\License Manager'
[14C0:6650][2025-03-05T07:32:53]i000: Unsetting variable 'ZOO_SERVER'
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'VC2013_version' to value '12.0.30501.0'
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'MSWebView2_Standalone_exists' to value 1
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'NOT SEND_STATISTICS' evaluates to false.
[14C0:6650][2025-03-05T07:32:53]i000: Registry key not found. Key = 'SOFTWARE\McNeel\Rhinoceros\8.0\License Manager'
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'NOT CUSTOMER_NAME' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'CUSTOMER_NAME' to value ''
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'VC2015_exists' to value 1
[14C0:6650][2025-03-05T07:32:53]i000: Setting numeric variable 'ReadEnableUpdatesKey' to value 1
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'VC2010_build' to value '167812379'
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'ReadEnableUpdatesKey' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'ENABLE_AUTOMATIC_UPDATES' to value '1'
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'NOT COMPANY_NAME' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i000: Setting string variable 'COMPANY_NAME' to value ''
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'VC2013_exists=1 AND VC2013_version>=v12.0.30501.0' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'VC2015_exists=1 AND VC2015_build>=33135' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'MSWebView2_Standalone_exists=1 AND MSWebView2_Standalone_version>=v116.0.1938.0' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i052: Condition 'CheckNETRuntime_Result=0' evaluates to true.
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: Redist_VC2013, state: Present, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: Redist_VC2015, state: Present, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: Redist_MSWebView2_Standalone, state: Present, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: rhino.msi, state: Present, cached: Complete
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: rhiexec.msi, state: Present, cached: Complete
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: en_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: fr_lang_pack, state: Present, cached: Complete
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: it_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: de_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: es_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: ko_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: ja_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: tw_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: cn_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: pl_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: cs_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: pt_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i101: Detected package: ru_lang_pack, state: Absent, cached: None
[14C0:6650][2025-03-05T07:32:53]i199: Detect complete, result: 0x0
[14C0:6650][2025-03-05T07:32:59]i200: Plan begin, 19 packages, action: Uninstall
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleRollbackLog_fr_lang_pack' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_000_fr_lang_pack_rollback.log'
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleLog_fr_lang_pack' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_000_fr_lang_pack.log'
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleRollbackLog_rhiexec.msi' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_001_rhiexec.msi_rollback.log'
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleLog_rhiexec.msi' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_001_rhiexec.msi.log'
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleRollbackLog_rhino.msi' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_002_rhino.msi_rollback.log'
[14C0:6650][2025-03-05T07:32:59]i000: Setting string variable 'WixBundleLog_rhino.msi' to value 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_002_rhino.msi.log'
[14C0:6650][2025-03-05T07:32:59]w321: Skipping dependency registration on package with no dependency providers: Redist_NetCore_WindowsDesktop_Runtime
[14C0:6650][2025-03-05T07:32:59]w321: Skipping dependency registration on package with no dependency providers: Redist_MSWebView2_Standalone
[14C0:6650][2025-03-05T07:32:59]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[14C0:6650][2025-03-05T07:32:59]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2013
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: ru_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: pt_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: cs_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: pl_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: cn_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: tw_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: ja_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: ko_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: es_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: de_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: it_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: fr_lang_pack, state: Present, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, cache: No, uncache: Yes, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: en_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: rhiexec.msi, state: Present, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, cache: No, uncache: Yes, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: rhino.msi, state: Present, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, cache: No, uncache: Yes, dependency: Unregister
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: Redist_MSWebView2_Standalone, state: Present, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: Redist_VC2015, state: Present, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C0:6650][2025-03-05T07:32:59]i201: Planned package: Redist_VC2013, state: Present, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C0:2DF0][2025-03-05T07:32:59]i000: GetSystemDefaultLangID() returned 1036
[14C0:2DF0][2025-03-05T07:32:59]i000: GetUserDefaultLangID() returned 1036
[14C0:2DF0][2025-03-05T07:32:59]i000: GetOsLanguage() returned fr
[14C0:2DF0][2025-03-05T07:32:59]i000: version_NT64 = 10.0.0.0; service_pack =
[14C0:2DF0][2025-03-05T07:32:59]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[14C0:2DF0][2025-03-05T07:32:59]i000: ver_64 >= ver_win_10
[14C0:2DF0][2025-03-05T07:32:59]i000: Showing UI from C:\Users\UTILIS~1\AppData\Local\Temp\{B135445C-C734-423C-BC6C-EE429BF6074D}\.ba\fr\progress.htm
[14C0:6650][2025-03-05T07:32:59]i299: Plan complete, result: 0x0
[14C0:6650][2025-03-05T07:32:59]i300: Apply begin
[14C0:6650][2025-03-05T07:32:59]i010: Launching elevated engine process.
[14C0:6650][2025-03-05T07:33:01]i011: Launched elevated engine process.
[14C0:6650][2025-03-05T07:33:01]i012: Connected to elevated engine.
[305C:6374][2025-03-05T07:33:01]i358: Pausing automatic updates.
[305C:6374][2025-03-05T07:33:01]i359: Paused automatic updates.
[305C:6374][2025-03-05T07:33:01]i360: Creating a system restore point.
[305C:6374][2025-03-05T07:33:01]i361: Created a system restore point.
[305C:6374][2025-03-05T07:33:01]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{31eedc70-ae06-4e1c-bc31-22a65ec52a4b}, resume: Active, restart initiated: No, disable resume: No
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {6F588191-7B68-4DC0-A4BB-93CAC4F036AB}, package: ru_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {852EEBCF-3C96-430A-BCA3-9A1EC8B04984}, package: pt_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {A285D617-2649-4EBF-A12C-0E679F95A14F}, package: cs_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {660F6426-44E1-4186-A9E6-82794A85857F}, package: pl_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {080BCB88-41B8-4F2F-A8FD-9563A91F2147}, package: cn_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {6EB8A7DA-0F71-409C-AEF9-83ACEAD401C1}, package: tw_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {6C3E9CC3-7ED8-4A60-805A-11E758C57CD7}, package: ja_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {23E32AB4-F713-4E9C-ABFC-D45C56F2BC8C}, package: ko_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {05EDD9EE-B829-43B0-94CA-B238CAEEE350}, package: es_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {CC03DE6C-756E-441C-A215-C7EBC81450C7}, package: de_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {34FAC0F6-C8D5-4D9F-A5C6-E919EE234668}, package: it_lang_pack
[305C:6374][2025-03-05T07:33:01]i326: Removed dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {5546E02A-F370-47BF-9A1C-A6834F1B2D53}, package fr_lang_pack
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {5546E02A-F370-47BF-9A1C-A6834F1B2D53}, package: fr_lang_pack
[305C:6374][2025-03-05T07:33:01]i301: Applying execute package: fr_lang_pack, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[14C0:6650][2025-03-05T07:33:01]i319: Applied execute package: fr_lang_pack, result: 0x0, restart: None
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {063CF13E-B1BD-4411-BA0D-CF89E8AB87AD}, package: en_lang_pack
[305C:6374][2025-03-05T07:33:01]i326: Removed dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {F4E3B1BC-7BEA-49E4-86A3-A15EA19C7CC7}, package rhiexec.msi
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {F4E3B1BC-7BEA-49E4-86A3-A15EA19C7CC7}, package: rhiexec.msi
[305C:6374][2025-03-05T07:33:01]i301: Applying execute package: rhiexec.msi, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[14C0:6650][2025-03-05T07:33:01]i319: Applied execute package: rhiexec.msi, result: 0x0, restart: None
[305C:6374][2025-03-05T07:33:01]i326: Removed dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}, package rhino.msi
[305C:6374][2025-03-05T07:33:01]i329: Removed package dependency provider: {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}, package: rhino.msi
[305C:6374][2025-03-05T07:33:01]i301: Applying execute package: rhino.msi, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" CUSTOMER_NAME="" COMPANY_NAME="" LICENSE_KEY="*****" LICENSE_METHOD="" LICENSE_VALIDATION_CODE="*****" ZOO_SERVER="" DEFER_NET48_REBOOT="1" INSTALLDIR="C:\Program Files\Rhino 8\" ENABLE_AUTOMATIC_UPDATES="1" DISABLE_INTERNET_ACCESS="0" SEND_STATISTICS="1"'
[305C:6374][2025-03-05T07:33:02]e000: Error 0x80070666: Failed to uninstall MSI package.
[305C:6374][2025-03-05T07:33:02]e000: Error 0x80070666: Failed to execute MSI package.
[14C0:6650][2025-03-05T07:33:02]e000: Error 0x80070666: Failed to configure per-machine MSI package.
[14C0:6650][2025-03-05T07:33:02]i319: Applied execute package: rhino.msi, result: 0x80070666, restart: None
[14C0:6650][2025-03-05T07:33:02]e000: Error 0x80070666: Failed to execute MSI package.
[305C:6374][2025-03-05T07:33:02]i318: Skipped rollback of package: rhino.msi, action: Install, already: Present
[14C0:6650][2025-03-05T07:33:02]i319: Applied rollback package: rhino.msi, result: 0x0, restart: None
[305C:6374][2025-03-05T07:33:02]i323: Registering package dependency provider: {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}, version: 8.16.25042.13001, package: rhino.msi
[305C:6374][2025-03-05T07:33:02]i325: Registering dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}, package: rhino.msi
[305C:6374][2025-03-05T07:33:02]i301: Applying rollback package: rhiexec.msi, action: Install, path: C:\ProgramData\Package Cache\{F4E3B1BC-7BEA-49E4-86A3-A15EA19C7CC7}v8.16.25042.13001\rhiexec.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[14C0:6650][2025-03-05T07:33:02]i319: Applied rollback package: rhiexec.msi, result: 0x0, restart: None
[305C:6374][2025-03-05T07:33:02]i323: Registering package dependency provider: {F4E3B1BC-7BEA-49E4-86A3-A15EA19C7CC7}, version: 8.16.25042.13001, package: rhiexec.msi
[305C:6374][2025-03-05T07:33:02]i325: Registering dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {F4E3B1BC-7BEA-49E4-86A3-A15EA19C7CC7}, package: rhiexec.msi
[305C:6374][2025-03-05T07:33:02]i301: Applying rollback package: fr_lang_pack, action: Install, path: C:\ProgramData\Package Cache\{5546E02A-F370-47BF-9A1C-A6834F1B2D53}v8.16.25042.13001\redist\fr-fr\LanguagePack.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[14C0:6650][2025-03-05T07:33:03]i319: Applied rollback package: fr_lang_pack, result: 0x0, restart: None
[305C:6374][2025-03-05T07:33:03]i323: Registering package dependency provider: {5546E02A-F370-47BF-9A1C-A6834F1B2D53}, version: 8.16.25042.13001, package: fr_lang_pack
[305C:6374][2025-03-05T07:33:03]i325: Registering dependency: {31eedc70-ae06-4e1c-bc31-22a65ec52a4b} on package provider: {5546E02A-F370-47BF-9A1C-A6834F1B2D53}, package: fr_lang_pack
[305C:6374][2025-03-05T07:33:03]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{31eedc70-ae06-4e1c-bc31-22a65ec52a4b}, resume: ARP, restart: None, disable resume: No
[305C:6374][2025-03-05T07:33:03]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{31eedc70-ae06-4e1c-bc31-22a65ec52a4b}, resume: ARP, restart initiated: No, disable resume: No
[14C0:6650][2025-03-05T07:33:03]i399: Apply complete, result: 0x80070666, restart: None, ba requested restart:  No
=== Verbose logging started: 05/03/2025  07:33:01  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Users\UTILIS~1\AppData\Local\Temp\{B135445C-C734-423C-BC6C-EE429BF6074D}\.be\Bootstrapper.exe ===
MSI (c) (5C:04) [07:33:01:988]: Resetting cached policy values
MSI (c) (5C:04) [07:33:01:988]: Machine policy value 'Debug' is 0
MSI (c) (5C:04) [07:33:01:988]: ******* RunEngine:
           ******* Product: {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}
           ******* Action:
           ******* CommandLine: **********
MSI (c) (5C:04) [07:33:01:990]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (5C:04) [07:33:01:990]: Grabbed execution mutex.
MSI (c) (5C:04) [07:33:01:991]: Cloaking enabled.
MSI (c) (5C:04) [07:33:01:991]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (5C:04) [07:33:01:991]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (DC:A8) [07:33:01:995]: Running installation inside multi-package transaction {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}
MSI (s) (DC:A8) [07:33:01:995]: Grabbed execution mutex.
MSI (s) (DC:80) [07:33:01:996]: Resetting cached policy values
MSI (s) (DC:80) [07:33:01:996]: Machine policy value 'Debug' is 0
MSI (s) (DC:80) [07:33:01:996]: ******* RunEngine:
           ******* Action:
MSI (s) (DC:80) [07:33:01:996]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (DC:80) [07:33:01:996]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (DC:80) [07:33:01:998]: SRSetRestorePoint skipped for this transaction.
MSI (s) (DC:80) [07:33:01:999]: MSCOREE not loaded loading copy from system32
MSI (s) (DC:80) [07:33:02:000]: End dialog not enabled
MSI (s) (DC:80) [07:33:02:000]: Original package ==> C:\WINDOWS\Installer\a0a358.msi
MSI (s) (DC:80) [07:33:02:000]: Package we're running from ==> C:\WINDOWS\Installer\a0a358.msi
MSI (s) (DC:80) [07:33:02:003]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (DC:80) [07:33:02:003]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (DC:80) [07:33:02:003]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (DC:80) [07:33:02:003]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}'.
MSI (s) (DC:80) [07:33:02:003]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (DC:80) [07:33:02:008]: Machine policy value 'DisablePatch' is 0
MSI (s) (DC:80) [07:33:02:008]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (DC:80) [07:33:02:008]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (DC:80) [07:33:02:008]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (DC:80) [07:33:02:009]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}'.
MSI (s) (DC:80) [07:33:02:009]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (DC:80) [07:33:02:024]: Transforms are not secure.
MSI (s) (DC:80) [07:33:02:024]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\UTILIS~1\AppData\Local\Temp\Rhino_8_20250305073253_002_rhino.msi.log'.
MSI (s) (DC:80) [07:33:02:024]: Command Line: ARPSYSTEMCOMPONENT=1 MSIFASTINSTALL=7 CUSTOMER_NAME= COMPANY_NAME= LICENSE_KEY=********** LICENSE_METHOD= LICENSE_VALIDATION_CODE=********** ZOO_SERVER= DEFER_NET48_REBOOT=1 INSTALLDIR=C:\Program Files\Rhino 8\ ENABLE_AUTOMATIC_UPDATES=1 DISABLE_INTERNET_ACCESS=0 SEND_STATISTICS=1 REBOOT=ReallySuppress IGNOREDEPENDENCIES=ALL REMOVE=ALL CURRENTDIRECTORY=C:\Users\Utilisateur\Downloads CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=12380
MSI (s) (DC:80) [07:33:02:024]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{9FF16BF8-A18E-49C9-8BF4-BEBF4179985F}'.
MSI (s) (DC:80) [07:33:02:024]: Product Code passed to Engine.Initialize:           '{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}'
MSI (s) (DC:80) [07:33:02:024]: Product Code from property table before transforms: '{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}'
MSI (s) (DC:80) [07:33:02:024]: Product Code from property table after transforms:  '{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}'
MSI (s) (DC:80) [07:33:02:024]: Product registered: entering maintenance mode
MSI (s) (DC:80) [07:33:02:024]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-user.
MSI (s) (DC:80) [07:33:02:024]: PROPERTY CHANGE: Deleting ALLUSERS property. Its current value is '1'.
MSI (s) (DC:80) [07:33:02:024]: Product {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5} is admin assigned: LocalSystem owns the publish key.
MSI (s) (DC:80) [07:33:02:024]: Product {F4A49066-EB88-4498-A3EF-6CF65FCEDCA5} is managed.
MSI (s) (DC:80) [07:33:02:024]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (DC:80) [07:33:02:024]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (s) (DC:80) [07:33:02:024]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (DC:80) [07:33:02:025]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (DC:80) [07:33:02:025]: Note: 1: 1729
MSI (s) (DC:80) [07:33:02:025]: Produit : Rhino 8 -- La configuration a  chou .
MSI (s) (DC:80) [07:33:02:025]: Windows Installer a reconfigur  le produit. Nom du produit : Rhino 8. Version du produit : 8.16.25042.13001. Langue du produit : 0. Fabricant : Robert McNeel & Associates. R ussite de la reconfiguration ou  tat d
MSI (s) (DC:80) [07:33:02:027]: MainEngineThread is returning 1638
MSI (s) (DC:A8) [07:33:02:027]: No System Restore sequence number for this installation.
Une autre version de ce produit est d j  install e. L{F4A49066-EB88-4498-A3EF-6CF65FCEDCA5}
MSI (s) (DC:A8) [07:33:02:027]: User policy value 'DisableRollback' is 0
MSI (s) (DC:A8) [07:33:02:027]: Machine policy value 'DisableRollback' is 0
MSI (s) (DC:A8) [07:33:02:027]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (DC:A8) [07:33:02:027]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (DC:A8) [07:33:02:027]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (5C:04) [07:33:02:029]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (5C:04) [07:33:02:122]: MainEngineThread is returning 1638
=== Verbose logging stopped: 05/03/2025  07:33:02 ===
Based on the log file you provided, the main issues identified are as follows:
This says that the Rhino.msi pacakge, which is embeded in the exe installer, coud not be run. This kind of problem is generally the result of a virus scanner deleteing things whiel Rhino installer is trying to run. Pls temporarily disable the virus/malware scanner and try installing Rhino again.
