When I try to import a skp file into Rhino 6 for Mac I always get an error.
I checked many time all the import options but nothing works.
Hi Jakob -
In Rhino 6, I created a box and exported that as a Sketchup file. Deleted the box in Rhino and imported the Sketchup file. That seems to work fine here. Does this behave differently on your system?
If it works with a box, can you post the Sketchup file that you are having issues with?
Could you post the error message?
This is the error I get.
I tried different units in the rhino model (mm to m)
unchecked prompt etc etc but nothing works.
and here is the skp file
HDK_WestGalerie.skp (4.4 MB)
and with a box as you mentioned it works fine.
Hi Jakob -
I see that this doesn’t work in Rhino 6. Rhino 7 has no problems with that file, so something got changed along the road.
