Import Options from Windows to Mac using .ini file
Hello!
As I understand it, Rhino for Mac does not yet have the commands OptionsImport/OptionsExport which would be used to import/export options (specifically aliases) on Windows using a .ini file.
When I try to ‘import aliases from a file’ in Rhino for Mac preferences, .ini files are greyed out.
Is it possible to take Windows options to Mac or do I have to enter each alias manually.
Thanks in advance,
J
from windows, can you export the aliases as .Txt ?
if so, those can be imported into rhino for mac.
Thank you, I’ll try that out!
Edit: Worked like a charm.
