Import Model block definition does not work with linked embedded
The ‘Import Model Block Definition’ command does not work with linked and embedded blocks, despite specifying the correct parameter, it inserts the block only as embedded. Am I doing something wrong?
What do you do with a baked block definition in Rhino?
Anyway, I think the update type is ignored. Also when baking a block instance…
@kike?
block_linked.gh (12.6 KB)
This is the linked block file to import:
m6x60-cap.3dm (114.8 KB)
Hi Martin, thanks for your reply. Maybe it’s the wrong approach, but I’m trying to find a way to create a command that works on both Windows and macOS, able to import files from Google Drive as Linked and Embedded Blocks into the Rhino session. I tried with Python with no success, and now I’m experimenting with GH Player. Any advice is more than welcome, thanks again.
I’m using Grasshopper to import linked blocks from Onedrive but I rarely bake the content into a Rhino file. Anyway, I was wondering what @kike or @AndyPayne suggest? Maybe the baking needs a small fix so baking is possible with all the options (linked / linked embedded)
