Bake Linked blocks instead of embedded
@AndyPayne or @Japhy would it be possible to add an option to bake linked blocks so they end up as linked blocks in the Rhino file?
At the moment it seems this is not possible.
Hi Martin,
Looking at the code, the Update Type on Import Model Block Definition gets overwritten when the file is imported, so the block always bakes as embedded even with Linked set. Same thing you and Lorenzo hit here.. Import Model block definition does not work with linked embedded i’ve logged it RH-99080 along with blocks referenced from the model losing their link, @kike should be able to take a look.
Thanks @Japhy , glad it got logged
