I expêrienced some instability when uploading scripts to the platform: specifically on the shapediver import node. Uploading the same code it sometimes showed it (as an import parameter) and sometimes not there at all. When it used to load the file, it set the file name and ran the computation, now the line next to the paperclip stays blank. Sometimes a crash screen appears stating only ! an error has ocured. When the import itself was not loading , it stated : loggingLevel: Input could not be validated. undefined is not of type enum. Please help ![]()
Please include a minimal grasshopper definition or at least the link to a ShapeDiver model showing the issue.
Hey @mathieu1,
i tried several scripts and they all have the same buggy behaviour;
heres a simple one that has it
uploadtestshapediver.gh (13.3 KB)
link is here: https://www.shapediver.com/app/m/pYUMUmOsBOV9vM8cfD3ZTtKpCc822g
This is a temporary issue related to an update we made earlier today. A fix is on the way, this should be solved within the next hour.
ah, explains a lot…![]()
thank you for the quick response, will retry soon
@Michael_Bonne The issue should be resolved now, please let me know if you still run into issues.
Yes perfect thank you, it is stable again…
