Import from sketchup not ok
targil_0101 bad import.3dm (2.6 MB) I am trying to import a sketchup file into Rhino,
It is opened OK, but in render mode - I can’t see material colors, nor layer colors in shaded mode.
I did it a few days ago, and it was all perfect.
Looks that may be some definition has changed, but I can’t imagine which…
I added a surface near it, and colors of it perfect.
How can I solve it?
I attach the Rhino file,
and this is command history:
File “C:\Racel Works\ויריי לסקטשאפ ארכיזוב 28 08 15\targil_0101.skp” successfully read
1 surface added to selection.
Command: _Hide
Command: _Zoom
Drag a window to zoom ( All Dynamic Extents Factor In Out Selected Target 1To1 ): _Extents
Display mode set to “Rendered”.
Creating meshes… Press Esc to cancel
1 polysurface added to selection.
1 object changed to layer “wall01”.
1 object changed to layer “wall02”.
1 polysurface, 1 curve added to selection.
2 objects changed to layer “glass”.
2 objects changed to layer “alum”.
1 object changed to layer “alum”.
Command: _Plane
First corner of plane ( 3Point Vertical Center Deformable ):
Other corner or length ( 3Point ):
Command: _CommandHistory
Thanks a lot
Rachel
This is what I get from the file you sent. I have always had the material show up. Your indvidiual objects under materials are set to object instead of layer. So they won’t take on layer properties. I’ve attached 2 images, one unmodified. One changing materials to layer instead of object.
I’ve attached an image with the properties palette to show you what I was talking about.
GREAT !! Thank you very much !!
