I downloaded the file igs of hull which is availble on KCS website. But to my surprise i tried to join surfaces but they are not joining after that i used join 2 naked edges command but still it seems the solid is not made… I am confused
I have just started using Rhino help will be appreciated… Thanks
Join command should be enough, it doesn’t require to select edges, only the surfaces.
…if the surface edges are within the file tolerance… Maybe they are not - you never know when something has been modeled in another system. You can try loosening the file absolute tolerance and see if that helps any.
Agree, only by looking into that file we can advise properly
Recent thread about joining surfaces of a KCS hull:
Yup the only issue was of tolerance. Godd i was so frustrated by the way everybody thanks very few times i saw such a active community
