If uploading takes a long time, pushing to yak will fail
Dear all,
When pushing the created yak file, it fails if the file size is large.
The file size is about 600MB, which is large, and my internet connection is slow, so I think it is failing because the upload is taking a long time. Is there a setting such as an upload timeout?
Hey @hiron,
Is this thread the same as your issue?
– cs
Hi @CallumSykes,
Thank you for your response
Yes, it seems to be same error.
As mentioned in the article, it sometimes works, but in most cases it does not. If you need additional information, please post it in this thread or the thread you mentioned.
Hi @hiron, that’s a very large package! I had another user run the following test, and I’m wondering if you could try too. Can you please try uploading your package file using our tech support file-upload form and make a note of the time it takes, if successful?
https://www.rhino3d.com/upload
Hi @will
I uploaded my yak file and it tooks about 20sec.
Thanks for testing that! I just messaged you with an alternate package server URL to try.
