Can anyone please guide me to fix this error
thank u
network surface.3dm (4.9 MB)
when i cap this
Hi @thaibui
NetworkSrf
will make a single NUBS surface with no kinks in it, so you need to either round the corners of the top “inflated square” or divide the body up into more parts - see attached.
HTH, Jakob
thank you @Normand
Unfortunately I can’t view the file you sent and I use version 5
Hi @thaibui
When you’re using a version other than the current (which is V8), it might be a good idea to mention it on the post - quite a lot has happened since 2012, when V5 came out. But here’s the file in V5 format:
network surface_JN_V5.3dm (1.6 MB)
-Jakob
