Network Surface seems to be failing for the attached curves. Any suggestions?
Thanks,
Sam
NetworkSurfaceFail.3dm (328.9 KB)
Thanks,
Sam
I suggest you rebuild your curves to clean them up and get their point counts the same. Then use sweep 2 rails. Even if don’t rebuild the curves you will get a more accurate surface with sweep 2.
That worked, thanks Stratosfear,
Sam
