btw. it is stuck there so many times
I donât know why you would be having problem logging into your account unless you are behind a firewall.
To use a single computer license on multiple computers, you need to use the Cloud Zoo, and that requires that Rhino.exe must be able to contact:
https://accounts.rhino3d.com (TCP port 443)
https://cloudzoo.rhino3d.com (TCP port 443)
Can you login to your account and see your license using the Web based portal?
https://accounts.rhino3d.com/?controller=home
Once every 2-3 months, youâll be asked to login again to refresh your account credentials.
Google requires this once a month.
Your on-line bank probably requires it every 10-15 minutes.
It happened again⊠I lost 10 hours of work.
I was working on a file for a pretty long time, then I closed my mac to standby, reopened to continue but Rhino was asking me to connect to cloud zoo, then it freezes there all the time.
If you forget to save your file it will be lost this is ridiculous guys. Rhino5 was better - this whole Cloud Shit made everything so complicated guys
MacOS is supposed to be automatically saving your file continuously via âversionsâ⊠how is it possible to lose 10 hours of work?
I didnât recognise it⊠I saved it a lot via cmd-S so I thought it#s all ok. Once it was too late I saw it was a read-only document and I donât know for what reason that happened or why Rhino wonât send me a notification that auto-save is not working.
Yeah, I hear you. Anyone used to the âpersonal responsibilityâ system where you as the user assume control of how your information is saved (or not) will be frustrated by Appleâs usurpation of that function. On the other hand, I have seen it save the bacon of a number of people who âforgot to saveââŠ
A warning message when trying to save a read-only file would be good though.
Could you elaborate what the actual problem was? I was thinking that he couldnât save because Rhino wasnât activated so it wasnât giving permission to save the file. I always manually save my files and never encountered a problem like that, so I donât think this is a Mac specific limitation, or maybe Iâm missing something Iâm not aware of.
Thanks,
José
Rhino couldnât save because the file was read only and I didnât realise that. I saved several times via CMD+S, but never got a message that saving wonât work. maybe the developers should implement a warning hereâŠ
The file was gone because of this, but I had to force close Rhino because it is so often stuck in âConnecting to Serverâ and then âDownloading Profile Pictureâ â and there it hangs around hours and nothing happens.
did you read this?
