I created a custom CPlane set at an angle compared to the World Top one
I saved this CPlane under a custom name
I then did “set CPlane” in the Front, Top and Right views.
Result:
The grid in those views did change, but the “cameras” of them did not.
Expected Result:
When I set a CPlane in the Front view, I expect the view to update and always keep the grid perpendicular to the view, not the other way around!
What additional step am I missing?
Also, when I set the CPlane in the Front view, I’m suddenly allowed to orbit that view in 3D space with my 3DConnexion mouse, instead of just panning it in 2D space. This is very bad!
Feels as this should be a macro… whenever you update the CPlane, all ortho views should silently run “set cplane” and then “set camera” to update whatever you did to it…
Hmm… in Front, I was able to do “set cplane” and then “set camera” and have the navigation back to 2D, but when I do the same in “Right”, the navigation is still 3D, ruining the perpendicular view…
Even weirder, when I create a line in that now updated orthogonal view, the line seems to be locked to the CPlane … I can’t place it anywhere else even with osnap off!
i don’t believe any view is restricted in movement, you can Shift+Cntl to start to orbit.
Do you have project on? This will constrain the snaps to the Cplane. Rhino will try and guess what plane you are drawing in, so if nothing is in the view i suppose it would always to to the cplane.
There are others around here that are much more experienced in these manipulations. I’ve never used Alias and can’t be of much more help in the translation of workflows.
Hello - I’m not sure how you’re doing it, but to ‘set camera’, use the Plan command. That will set a plan ortho view that should not behave any differently from the standard ones as far as navigation goes.
Thank you, that worked for the Front view, but if I do the same for Top and Right, they become the exact same view. And if I try to change, say the Top view to Cplane Top via the menu after plan, I get 3D rotation again.
