I can't run _SubDDisplayToggle in R7
Hello everyone. Since I installed R7 I am unable to execute the SubDDisplayToggle command. I tried assigning a different key, but nothing helped. I don’t know what can be wrong. Thanks.
Happy 2021
Hello - are you saying the Tab key does not work, or the command if typed, or both, or?
None of them work
Hello - can you please run SystemInfo in Rhino and copy/paste the results here? And, the SubD display you see and cannot change is smooth or faceted?
@Plasmeo3D - the SubDDisplayToggle both autocompletes and echo the current state to the command line.
Command: SubDDisplayToggle
SubD display changed from smooth to flat.
SubD display changed from flat to smooth.
Are you not seeing this?
– Dale
boa noite , estou tendo a mesma dificuldade, após ter desinstalado do meu Pc o rhino7, ao reinstala-lo o comando subdDisplay Toogle não funciona mais.
Hello- does _SubDDisplayToggle + Enter work if you type on the command line?
