TAB key in V7
Hi Guys, is the TAB-key going to be hard-coded for SubD display toggle?
Asking since we are using bunch of scripts that currently have TAB press coded as different functions and now in WIP it also results in the SubD display toggle. I am trying to figure out if there would be a way to temporarily disable TAB SubD switch for the scripts runtime, or better yet, have TAB fully customizable as Function keys, could be SubD switch as default toggle ?
thanks,
–jarek
tab tab ?
The TAB key does lots of things in Rhino. For the time being, its hard coded behavior will continue. More details at https://mcneel.myjetbrains.com/youtrack/issue/RH-55227
Hi @dalelear - this has been already adressed in V7 and Tab has been made configurable. Hope it can stay that way. Thanks~
https://mcneel.myjetbrains.com/youtrack/issue/RH-57554
–jarek
Yup. My mistake. When I searched for issues, I missed seeing 57544 and thought 55227 was the currentl situation. Mikko is a key handling wizard and you guys get to use the TAB key as you see fit.
