I can’t manage to apply my 2D facade to the four faces of a cube. The pattern either distorts at the corners, doesn’t connect properly between faces, or only appears on one surface. I’ve tried using Project and Brep Components but can’t get the continuous wrap effect I need. Are there any specific Grasshopper components or techniques to seamlessly map a 2D pattern across multiple adjacent faces?I
no script to look for only screenshot available which is hard to read
i think Rectangle mapping you are looking for
