I use Rhino regularly in my old computers. The extrude straight command always make solid object out of curves as a default state. Anyway, recently I just got a new laptop and has installed Rhino for the first time. This command is set to be “Solid=No” that I need to assign ‘s’ every time I summon it and that’s really annoying.
How can I fix this issue!
Thanks!
How are you calling the command?
Oh! I use command “Extrude straight” in my pop-up window, but when you mentioned this, I tried the same command but located in its original toolbar. The icon is the same except the name that is “Extrude closed planar curve” and it works!
Thank you! The problem has been solved!
