Hi, I am trying to render something in Raytraced view and Ive noticed the app uses CPU Intel Iris instead of GPU Nvidia GeForce so it is taking forever. I cant even change it under options-cycles. What do I do?
According your screenshot you don’t have any supported Nvidia GPU. You need at least a Maxwell-based GPU.
Please run the Rhino command _SystemInfo and post the result in a reply. That should tell us enough about whether it should show or not.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: tion, build 2020-12-08
License details: Stand-Alone
Windows 10.0.22631 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Laptop GPU (NVidia) Memory: 4GB, Driver date: 11-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.17
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-9-2023
Driver Version: 31.0.15.4617
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
You should
Make sure you updated to a non-cracked installation of the latest Rhino 7 service release, yours is more than 30 service releases behind. Rhino 7.1 didn’t support yet RTX 3050, but latest 7.35 and 7.36 do.
Unofficial Rhino versions like this are bound to run into problems. You can’t be certain that any cracks applied have not altered the working of Rhino.
You probably need to buy a valid licens too. tion is not a valid license type.
Ensure you have all Windows 10 updates installed, you’re behind on this quite a bit too.
Update your GPU drivers to the latest available for your model.
