Rhino 8 Raytraced only on CPU
Wanted to render something via Raytraced.
Only works via CPU. :frowning:
Can’t find “Cycles” in the properties.
Thought rendering in Rhino 8 might be better than before.
Still annoying.
The problem is probably in front of the computer…
What should I do?
Better to spare my nerves and do it in again in another program…
Here is my system Info… maybe someone can help after all…
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001)
License type: Educational, build 2025-03-07
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 532.27
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-9-2023
Driver Version: 31.0.15.3227
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
Your nvidia drivers are very out of date.
Take a look at this topic, also from today. It has info on updating those video drivers:
As already mentioned the driver here is way too old. When you do the update ensure you do a clean install (check options in installer, there is one for it you need to check).
“Problem” with driver fixed…
Render version: 4.6
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Still the same…
Go to Tools > Options > Rhino Render and hit the Recompile kernels button. If after a while the dot after your device doesn’t turn green from orange hit the Show compile logs. Copy and paste the results from that log here please.
Note that it can take several minutes or more for the kernels to be compiled.
@ Nathan ‘jesterKing’ Letwory
Thank you very much!
After compiling the kernels its working fine.
Had some strange bugs with the output vom capture to file, different Image details, depending on display modes… but I’ll have to take a closer look first… maybe just a wrong setting
