The idea is to create an air traffic control tower with a spiral of light entering the interior. The issue I am having is how to create a script that keeps the hyperbolic shape but allows for changeable turns and pitches in the openings. (Similar to how the helix command works in Rhino)
Damn You @davezov000 !!!
I came back from a Saturday night exit and I thought “why not check the forum for a couple of minutes?”
I found your question intriguing so here I am, two hours later solving your problem. hahaha
I hope at least it helps you get a good grade
The opening ‘ribbon’ is not controled by its vertical opening, but rather from the rotation of the spiral.
(sorry, the enthusiasm is over for tonight)
Goodnight!
edit: as you change the spiral turns, the surface numbering might change so you have to tweak the list item components near the end of the definition in order to select the correct subset of surfaces for the creation of the wall.
Would it be possible to create those straight columns as well? That follow the same curvature, but are rigid.
Or is this something to do separately after baking into Rhino?
