Sorry, I am a newbie in GH with the big letter “N”.
My goal is to create a 2D rectangular spiral to simplify my project work (radiant heating floor). The total length of the spiral is limited, the offset of turns is variable.
Any ideas are welcome, thanks!
Hey, so I tried this code and modified it to apply it to a non-rectangular room, a more irregular curve, and this is happening to me. Is there a way to fix it?
Hi, I have been looking for the same thing for a long time now, but both of these approaches have killer limitations. 1. You made these scripts specific to the shape you were using (room layout and dimensions); if the room were much bigger, the center would be just empty. 2. If you can’t specify the max circuit length and you have to do it manually, then, i guess, just do the entire thing manually because it takes more time to separate than to just draw it manually. I’m working on this project to find a better solution, and any kind of help or idea would be appreciated.
