Human UI Help - Changing color of meshes?
I’m trying to create a Facade UI with Human UI (attached is a simplified version of what I mean).
do you know if it’s possible to change the color of different meshes referenced in the same window? (so the custom preview but applied to different meshes) Hopefully the screen shot showing the difference between the Rhino window (where a selected panel is given one color) and the HumanUI (where everything has one color).
Also attached gh file
thanks!
humanui.gh (17.0 KB)
“Create 3d view” and “set 3d view” both take a list of meshes and a list of colors. If you supply multiple colors and multiple meshes, it will assign each color to the mesh. Just don’t join the meshes before you add them to Set 3d view :slight_smile:
Could you please provide me with an example? I’ve tried many times and unfortunately haven’t succeeded.
