How would you create this curved surface?
I could use a curve, and after that split the main body to make the curve in the body
But if I’m not wrong, there should be a tool that can make that function…
Imgur
I would draw one horizontal line, plus one inclined line, and then use “! _Fillet” to create the round transition between both lines.
Hi there!
If I understand your question correctly, so as to what command allows you to cut through the body without leaving you with the burden of topping it of… than your answer is: _WireCut
This will only work if the desired result is a single curvature surface.
If this is not the answer you were looking for, please rephrase your question.
-Riccardo
Do you have in mind the round surface only, which is marked with the green line? If that’s the question, then the answer is to use either “Fillet edges” (for G1 continuity) or “Blend edges” (for G2 continuity).
