Having issues importing this particular DWG into Rhino. Any tips? Tried following this Why Does My DWG / DXF Not Open in Rhino? [McNeel Wiki] but with no results. STL doesn’t work either as it isn’t water tight either.
Hello - I guess we need a bit more information, and/or a file. I can’t tell if the problem is in the import not working at all or the results from Import are not what you want, or? Is the file in dwg format? What happens when you use Import? If it comes in as an open mesh via stl, it is unlikely dwg will be any better.
