Is it possible to write equations in GH on Canvas?
something like that?
I could not find in ‘Scribble’ options
I guess maybe there is some way to do it
Looks like Pterodactyl | Food4Rhino has some LaTeX functionality
unfortunately it does not look good as per equation…this is only for documenting
thanks all for the help and suggestions I tried most of them…
<math xmlns="http://www.w3.org/1998/Math/MathML"><msub><mi>p</mi><mi>v</mi></msub><mo>=</mo><msub><mi>p</mi><mi>w</mi></msub><mo> </mo><mo>-</mo><mo> </mo><mfrac><mrow><mo>(</mo><msub><mi>p</mi><mi>b</mi></msub><mo>-</mo><msub><mi>p</mi><mi>w</mi></msub><mo>)</mo><mo>(</mo><msub><mi>t</mi><mi>d</mi></msub><mo>-</mo><msub><mi>t</mi><mi>w</mi></msub><mo>)</mo></mrow><mrow><mn>1544</mn><mo>-</mo><mn>1.44</mn><mo>×</mo><msub><mi>t</mi><mi>w</mi></msub></mrow></mfrac></math>
FormulaTest.gh (18.9 KB)
I wish Grasshopper would support and recognize MathML
Why not just add an image with the formula?
it does not look great or is editable in any sense…
but if we stuck to this option I guess in the end is the most readable…
I wish in the year 2023 when AI is flying all around we could write math formulas…seems this is beyond current technology … I will also test texstudio
You and me both. It is shockingly disappointing how many (what I would consider) basic features are lacking entirely in operating systems.
The fact that RTF is still a thing in 2023 just baffles the mind.
Hi Michal -
Well, that would be one way. I looked for an online \LaTeX editor, printed the result to PDF, and imported that PDF into Rhino.
Then put that in SLF-RHN Architect and exploded. Move and scale curves as required.
You create a scribble in GH, right-click, and pick Load from Rhino. Then select the curves in Rhino.
(You can first send the scribble to Rhino to make sure that the text curves are somewhat in the correct position).
This is a way to show curves as image in Grasshopper viewport or with image resource component.
Graphic+ plugin must be installed
image on canvas.gh (23.2 KB)
Nice link, @seghierkhaled, thanks.
For anyone installing this from Food4Rhino, I got a Windows warning that F4R was trying to open the WIP - this can be ignored as it actually opened R7. This is presumably another example of Windows being unable to identify different versions of Rhino. Note too that you can bypass F4R and install directly from the Package Manager in R7.
Regards
Jeremy
Hey @wim,
If I right click on a scribble I get this menu, not yours:
Same in R7 and WIP and in G2.
Do you maybe have a McNeel internal build?
Regards
Jeremy
How about this:
Cheers, Jaro
I made subscripts !!! ![]()
EquationsSketch.gh (22.6 KB)
Definitely in the need of sleep ![]()
Enough absurdity for one day !
Pterodactyl doesn’t need paid Typora, you can try with MarkText which is open-source: GitHub - marktext/marktext: 📝A simple and elegant markdown editor, available for Linux, macOS and Windows.
Typora is just a preferred editor ![]()
