How to write math formula on GH canvas?
Hi Jeremy -
Yes, sorry, a sketch, not a scribble.
Thanks, @magicteddy.
@w.radaczynski would you be so kind and open my GH script and check why it does not calculate as expected? Did I mess up the formula?
@magicteddy I am testing your solution …
but I can not find
Define Text Object
I already via this post added :slight_smile:
  • Peterodactyl
  • Metahopper
  • Graphic+
but seems is not part of these tools…
It’s from Elefront 4.2.2. It should provide you a way to download it when opening the file.
Here is the latest version (with the equation in three parts). But… be aware this is a workaround of a workaround :smiley:
It also seems Metahopper has trouble saving the reference to the sketch when the document is closed and reopened…
EquationsSketch.gh (33.0 KB)
I had to change slightly your panel input, but here is a result:
@w.radaczynski does Pterodactyl work with complex numbers? Thank you.
Pterodactyl is just a report creator. It creates a report that can be later opened in a markdown editor and export it to e.g. html or pdf. It’s free and open-source, so you can just test it yourself: Pterodactyl | Food4Rhino
Python code based on this link:
latex2png.gh (9.2 KB)
Using Aspose plugin
A red message of evaluation version appears when choose scale > 1500
With cos(x) instead of sin(x) that would be perfect :wink:
I have no idea
This is the right formula
This one using WPF-Math
But i think it is limited, some equations can’t created
latex2png_c#.gh (10.9 KB)
WPFMath dll
WpfMath.zip (126.2 KB)
