WeldVertices fails (Bug ?)
this is some data from one of my students.
i don t know how it was created.
picked / extracted from a bigger object.
i can t manage to join/weld/stitch those unwanted open edges / cuts with
_alignvertices
_weldvertices
why don t they weld?
how to do it ?
would be great if _weldvertices would use a tolerance.
and maybe if 2 single vertices are picked - a commandline feedback why it failed ?
thanks - kind regards - tom
WeldVertice_fail.3dm (3.1 MB)
(edit)
deleting and redrawing 2 faces works. (_appendFace)
but i expect some simple “glue with force” one or two click method
Hi @Tom_P,
if you use _Stich and Window select individually at the locations in below picture, it works.
Alternatively, you could use _WeldEdge on the small vertical edges above the numbers.
I can confirm that sometimes welding does not work as expected. A last resort is to _ExtractControlPolygon and weld this instead. Then convert back to subd.
_
c.
thanks.
welding, stitching, joining … edges vertices …
align first
use a tolerance…
@pascal or @theoutside
it would be nice to have a “superglue” command that brings together what ever is selected - even if it s technically different stuff in the background
+1, i hate it to try all possible commands until i eventually find what works and what not.
_
c.
Stitch should work on mesh and subd vertices and should collapse into a single if used on multiple verts.
