How to unfold a curve surface to a plane surface
I want to unfold a truncated oblique cone to a plane surface for fabrication as attached.
Surface for unfold.3dm (54.8 KB)
Is it possible?
Thanks
Hi Youngken - Use SrfSeam to move the seam to your cutting line, assuming it lines up, then UnrollSrf.
Hi Pascal,
After unfolding, I want to know whether the isocurve is divided by angle (45 degree) or not?
Hi Youngken - I have no idea but I’d think off hand that is very unlikely, unless by chance. You can test by adding lines every 45 degrees and unrolling with the surface.
