hello,
I am looking for help, I would like to make a cone(loft), then UnrollSrf, cut some holes or pattern on the unrolled surface. Then I would like to wrap this flat surface around the cone and give the surface thickness to see the result.
Is it doable in rhino?
Hello - see if the attached file helps - RollUpCurves.3dm (87.7 KB)
thank you very much, it helped me a lot
