Hello @dale,
I am converting a Rhino mesh object into Parasolid.
From Rhino I am getting a quadrangular mesh face. Now I want to Split each quadrangular mesh face into two triangles. I know that in Rhino thre is a command ‘TriangulateMesh’ whch can do this. But I am using Open NURBS SDK (C++) for converting Rhino model to Parasolid, so it will be helpful if you suggest us any API which can do the same.
Hi @psomesh94,
You might do something like the following:
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
CRhinoGetObject go;
go.SetCommandPrompt(L"Select mesh to triangulate");
go.SetGeometryFilter(CRhinoGetObject::mesh_object);
go.EnableSubObjectSelect(false, false);
go.GetObjects(1, 1);
if (go.CommandResult() != CRhinoCommand::success)
return go.CommandResult();
const CRhinoObjRef& obj_ref = go.Object(0);
const ON_Mesh* mesh = obj_ref.Mesh();
if (nullptr == mesh)
return CRhinoCommand::failure;
ON_Mesh new_mesh(*mesh);
new_mesh.RemoveAllNgons();
new_mesh.ConvertQuadsToTriangles();
new_mesh.CullDegenerateFaces();
new_mesh.Compact();
if (new_mesh.IsValid())
context.m_doc.ReplaceObject(obj_ref, new_mesh);
context.m_doc.Redraw();
return CRhinoCommand::success;
– Dale
