I do not know how to continue. I created a Klein bottle that is now visible as a Mesh Loft. I would need to thicken this Mesh Loft, and let it bake as a closed mesh.
How could I continue?
you can use Mesh offset from pufferfish or Mesh Thicken from Weaverbird
Thank you for your answer. Unfortunately, this doesn’t work.
Try 1:
Try 2:
Please note it’s a Mesh Loft and not just a Loft.
can you share your definition so I can help you by taking a look?
This issue has been solved, the original lofting mechanism has been corrected to avoid invalid mesh, so it is always a good practice to make sure no overlapping mesh faces occur.
@Svenja_Vogel please make this post as solved. thank you
Thank you so much!
