I am still new to Rhino and I would appreciate if you could guide me please on how to stop unloading the material layers, object, render, users and extra layers in Layer Tab as you can see in the attachment? They kept appear although I delete them every time I save the file.
Hi Nada - do these layers also appear when you start a new Rhino file from a factory-default template file? Can you please run the Rhino SystemInfo command and copy-paste the result here?
In that case, it’s MatrixGold that is creating these layers.
I have never used MatrixGold but perhaps there are settings that let you configure these things?
I’m afraid you’ll have to contact support at Stuller if that doesn’t help.
Hi Wim and thank you so much for your great help and assistance!
MatrixGold is already expired as it was a student version, so I will remove it from the system and see if this will solve the problem.
