When ever I open a new Rhino 5 the layers Panel still carries
and shows old layers from my previous work. This never happen
before 2019.
How do I clear these layers from the panel?
before 2019.
Hello - if you close and reopen the Layers panel, does it update? Does the status bar Layers pop-up show the correct layers?
No.
This issues never happen before.
Also my object “Types” would show old textures from previous work.
Hello - I guess I’d start with a reboot of the system and see if the problem persists.
Thanks for the help Pascal.
Let me try your solution.
One quick question.
Is there a way I can upload an image of the panel here in the discussion panel ?
Hello - you can copy and paste an image directly into the message as you type. If the problem persists after a reboot, please start a new file, make a change in the layer names and then open another new file - does that look correct?
Thank you.
I shall try.
Hi @lima,
What service release of Rhino 5 do you have? A screen capture of Rhino’s About
box might be helpful.
– Dale
I tried it now but not working.
Also I forgot to mention. These layers shows up only when I open Rhino through
Templates : Large Objects - Feet
I don’t have issues in the other templates.
Hello - I am confused - can you please tell me exactly every step needed to reproduce the problem from the time you open Rhino?
When ever I open my Rhino 5
New / Templates / Large Objects - Feet
The layers in my panels keep showing layers from my previous works
as shown in the the screen shot.
How do I clear these layers names?
Hello - it looks to me like the template file has been replaced, is all -
Large Objects - Feet.3dm (21.0 KB)
Here is the default one.
Thank you.
I downloaded your file and open, the layers name are cleared now.
But when I open my rhino in the usually way the problem still
remains.
Perhaps. I will have to reinstall it again.
Hello - please replace your template file with the one I posted.
