Layercolor isn't visible after changing OpenGPL settings
Hello!
The rhino file that I was working on was lagging a lot so after reading on how to resolve that in couple of places, I unchecked GPU tessellation and changed “Antialiasing” to none but after doing the layercolors don’t look the same anymore. Even if I tried to go back to the original setting, it doesn’t fix the problem.
The file is 50 MB hence I am not able to attach it but I am attaching screenshots of the problem and pasting the system info.
System info:
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03001, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: Educational, build 2023-04-17
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [83% battery remaining] ~267 minutes left
Primary display and OpenGL: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 8-20-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.100.9865
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 1.1
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: Not supported
Driver Date: 8-20-2021
Driver Version: 30.0.100.9865
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.29.23107.3001
Well, your computer video card is quite old and unfortunately terribly under spec for running Rhino. And having to dial it down to OpenGL 1.1 just to get it working isn’t going to be more than an emergency measure. You really need to have a better computer system if you are going to do anything serious with Rhino…
Thank you so much for responding! I understand what you’re saying.
