What to do when don't see materials in render view?
During my last project i am having troubles with rhino 8, it appears all in black, i cant see materials.
Please run the Rhino command _SystemInfo and post the result in a reply.
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Educacional, revisiĂłn 2024-03-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “NavegadorWeb”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Herramientas Rhino Labs”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “ProcesadorInactivo”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Renderizado de Rhino” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
Please update your GPU driver to the most recent. At the moment that would be NVIDIA Studio Driver | 551.86 | Windows 10 64-bit, Windows 11 | NVIDIA . When you start the installer make sure to choos Custom/Advanced installation and check the Clean Install from the next page.
Any better?
Thanks a lot Nathan, but still the same. It is really weird i worked several times with cosmos bricks and never happened before.
Is the model far from origin? If so try moving it to around world origin and see if that helps
it is centered yes, is it any way to open the file without previous materials and reset everything to initial config?
Perhaps you can share the model for further investigation? You can share it with us confidentially using Rhino - Upload to Support . ZIP the 3dm file with all support files. I’ll have a look after the weekend.
Hello Nathan, the problem is solved. Instead of trying to fix the model, or whatever it was, I have copied the objects to a clean file, no materials, textures or lights. Then I have applied the same materials and lights in teh new file and everthing work fine. Even the rendering is much faster now which make me think that maybe something was creating conflicts when processing the graphics. Thanks a lot for your help. Best regards.
