help me please, understand how to manage and create Displacement mesh.
how to implement and manage Resample Texture Settings in Displacement ?
I can’t create a deformed mesh.
using System;
using System.Collections.Generic;
using System.Drawing;
using System.Windows.Forms;
using Grasshopper.Kernel;
using Rhino;
using Rhino.Display;
using Rhino.DocObjects;
using Rhino.Geometry;
using Rhino.Render;
namespace GG_Render_Tools
public class GG_MeshDisplacement : GH_Component
public GG_MeshDisplacement() : base("MeshDisplacement",
"MeshDisplacement",
"Get Render Meshes",
"GGold", "Render")
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddTextParameter("Path", "P", "Path to Picture", GH_ParamAccess.item);
pManager.AddGenericParameter("Guid", "G", "The Object Guid", GH_ParamAccess.item);
pManager.AddBooleanParameter("Get", "G", "Get Render Meshes", GH_ParamAccess.item, false);
pManager.AddBoxParameter("Box", "Box", "Box", GH_ParamAccess.item);
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddMeshParameter("Mesh", "M", "Render Meshes", GH_ParamAccess.item);
pManager.AddGenericParameter("RenderTexture", "G", "The Object Guid", GH_ParamAccess.item);
pManager.AddGenericParameter("TextureMapping", "G", "The Object Guid", GH_ParamAccess.item);
protected override void SolveInstance(IGH_DataAccess DA)
try
Box unset = Box.Unset;
string text = "";
Guid guid = new Guid();
bool add = false;
List<RhinoObject> list = new List<RhinoObject>();
if (!DA.GetData(0, ref text)) return;
if (!DA.GetData(1, ref guid)) return;
DA.GetData(2, ref add);
if (!DA.GetData(3, ref unset)) return;
RhinoObject objj = Rhino.RhinoDoc.ActiveDoc.Objects.FindId(guid);
if (objj != null)
list.Add(objj);
if (objj != null)
// Get render meshes from the object
var renderMeshes = objj.GetMeshes(Rhino.Geometry.MeshType.Render);
if (renderMeshes != null && renderMeshes.Length > 0 && renderMeshes[0] != null)
// Create mapping mesh from render meshes
Mesh mappingMesh = new Mesh();
foreach (var renderMesh in renderMeshes)
if (renderMesh != null)
mappingMesh.Append(renderMesh);
for (int vi = 0; vi < mappingMesh.Vertices.Count; vi++)
// Point2f tc = new Point2f(mappingMesh.Vertices[vi].X, mappingMesh.Vertices[vi].Y);
// mappingMesh.TextureCoordinates.SetTextureCoordinate(vi, tc);
// Create custom mesh texture mapping
// TextureMapping textureMapping = TextureMapping.CreateCustomMeshMapping(mappingMesh);
// Apply mapping to object
// objj.SetTextureMapping(1, textureMapping);
Texture texture = new Texture();
texture.FileName = text;
texture.TextureType = TextureType.Bitmap;
var doc = RhinoDoc.ActiveDoc;
int index = doc.Materials.Add();
Rhino.DocObjects.Material mat = doc.Materials[index];
mat.SetBitmapTexture(texture);
// mat.SetBumpTexture(text);
mat.Name = "Testing";
mat.CommitChanges();
objj.CreateMeshes(MeshType.Render, MeshingParameters.QualityRenderMesh, false);
Rhino.DocObjects.ObjectAttributes attr = objj.Attributes.Duplicate();
attr.MaterialIndex = index;
attr.MaterialSource = Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject;
objj.Attributes = attr;
objj.CommitChanges();
doc.Views.Redraw();
// RenderMaterial rm = Rhino.Render.RenderMaterial.CreateBasicMaterial(mat);
// var diffslot = rm.TextureChildSlotName(Rhino.Render.RenderMaterial.StandardChildSlots.Diffuse);
// var s1 = rm.FindChild(diffslot) as Rhino.Render.RenderTexture;
// hino.Render.RenderTexture s1 = rm.GetTextureFromUsage(Rhino.Render.RenderMaterial.StandardChildSlots.Diffuse);
Rhino.DocObjects.Material matt = RhinoDoc.ActiveDoc.Materials[objj.Attributes.MaterialIndex];
Rhino.Render.RenderTexture s1 = matt.RenderMaterial.GetTextureFromUsage(Rhino.Render.RenderMaterial.StandardChildSlots.Diffuse);
Rhino.Render.TextureMapping s2 = TextureMapping.CreateBoxMapping(unset.Plane, unset.X, unset.Y, unset.Z, true);
s2.Name = "name";
if (s1 != null || s2 != null)
objj.SetTextureMapping(1, s2);
// objj.CommitChanges();
// mm.TextureCoordinates.SetTextureCoordinates(s2);
// mm.SetTextureCoordinates(s2, tfm, false);
// mm.SetCachedTextureCoordinates(s2, ref tfm);
// s1 = matt.RenderMaterial.GetTextureFromUsage(Rhino.Render.RenderMaterial.StandardChildSlots.Diffuse);
// var rt = Rhino.Render.RenderTexture.NewBitmapTexture(simulated, Rhino.RhinoDoc.ActiveDoc);
// var t = s1.SimulatedTexture(RenderTexture.TextureGeneration.Allow).Texture();
Rhino.Geometry.MeshDisplacementInfo k = new Rhino.Geometry.MeshDisplacementInfo(s1, s2);
k.ChannelNumber = 1;
// k.PostWeldAngle = 40;
// k.RefineSensitivity = 0.5;
// k.SweepPitch = 0.5;
// k.White = 0.1;
// k.WhiteMove = 0.1;
// k.Black = 0.5;
k.BlackMove = 0.5;
k.FaceLimit = 1000;
Mesh Rendermesh = new Mesh();
Rhino.DocObjects.ObjRef[] meshObjRefs = Rhino.DocObjects.RhinoObject.GetRenderMeshes(list, true, false);
if (null != meshObjRefs)
for (int i = 0; i < meshObjRefs.Length; i++)
Rhino.DocObjects.ObjRef meshObjRef = meshObjRefs[i];
if (null != meshObjRef)
Rhino.Geometry.Mesh mesh = meshObjRef.Mesh();
Rendermesh.Append(mesh);
DA.SetData(0, Rendermesh);
DA.SetData(1, s1);
DA.SetData(2, s2);
if (add)
if (null != Rendermesh)
RhinoDoc.ActiveDoc.Objects.AddMesh(Rendermesh);
RhinoDoc.ActiveDoc.Views.Redraw();
catch (Exception ex)
MessageBox.Show($"An error: {ex.Message}", "Error", MessageBoxButtons.OK);
public override GH_Exposure Exposure
get
return GH_Exposure.primary;
protected override Bitmap Icon
get
return null;
public override Guid ComponentGuid
get
return new Guid("{87867d19-568f-4388-95e2-9f7adf731c94}");
