I have Rhino and Grasshopper for Mac.
Since a few days i’m trying to transform a surface into a regular triangle mesh.
I’m not very good at grasshopper so i tried to find a resolution in this Forum, but i couldn’t find some for my example.
Maybe there is somebody out there who can help me with my problem, what would be very nice.
What do you mean by “regular triangle mesh”… all the same size edges? You can use the Mesh command in Rhino directly followed by TriangulateMesh to get all tris. Does that help?
If not, explain more about what you need from the mesh. The polysrf has some issues at the poles of the trimmed ellipsoids but perhaps those won’t matter. I’m not sure you need GH here unless I’m missing something.
I’ve checked your surface and there seems to be a problem with the way it is modeled. If you run the check comand in rhino you will be able to see that it is not a valid surface.
The surfaces don’t mesh so I agree rebuilding those is important. The tips of the ellipsoid forms (poles) are the main factor in the polys becoming smaller in those areas when meshing simply with the Mesh command. If you can model trimmed surfaces without poles in those locations you may be able to use the detailed mesh controls to get evenly sized polys. Otherwise, it does seem GH would be needed.
Maybee you can tell me if it is possible to create a surface from points,witch i put on the surface.
Cause when i rebuild the surface by lofting, the sides will be not close.
Why do you require equal length edges in the mesh you’re trying to create? I think you can get close with detailed meshing of a trimmed surface but I don’t think it will be perfect.
