No, I am talking about grasshopper generated data.
(And as you can see in the bottom image I allready show curves and points in the arctic mode)
Edit: I updated the original post so it is more apparent.
Arctic is a kind of ‘rendered’ viewport, and as such only shows Grasshopper geometry that is present in a Custom Preview component. And only meshes at that, so no points and curves.
Then we need a CustomPreview for curves as well.
And please make CustomPreview display mode sensitive, because not being able to see an object in Shaded if it has a CustomPreview setting makes Grasshopper slower to use.
You’ll need to take that up @andy, as he has to make the custom render mesh pipeline flexible enough to support curves and points with styles.
I don’t understand. Custom Preview will either draw the stuff inside of it in a viewport if that viewport is not of the rendered type, or it will pass on it’s meshes and materials to Rhino and whatever Render engine is running so they can be included in the default display.
I know this topic is old, but I just ran into the same issue of rendering curves from GH as an animation (this makes it impossible for me to bake and set a layer material for every frame. the Human plugin has a custom line weight setting which converts lines into meshes so that they can be seen in the rendered viewport. https://www.food4rhino.com/app/human
