How to select loop/ring faces of SubD?
I can select edges loops or rings… but not faces, is there a special key that I need to be pressing?
Thanks
Shift double-click on the second face.
You need to have sub-object selection active.
Or by doing CTRL+SHIFT…
SubD face loop selection
First you select normally a face, then you SHIFT + double click an adjacent face, it will select all the loop.
or
First select a face, then SHIFT + select another face that is not adjacent, lastly SHIFT + double click a face inside the previous 2, it will “fill” the selection.
