How to see results of a specific load case of a load comb
I downloaded the Night Build Release. I want to study a simple supported beam and I created three Load cases (q1, q2 and Q1) and two Load Combinations. It seems that with the Load-case Selector it is possible to see the results obtained not only from a specific load combination, but also from a single load case of this combination, and that’s what I’m trying to do. But by selecting the combination (in the figure you can see that I selected the ‘SLE’ combination), it isn’t possible to select a single load case, for example ‘q2’ (first figure). Why’s that?
In the second figure you can see the ‘SLE’ combination and its components (single load cases in it).
Thank you very much for your help.
Hi, you have to select it from the Load Case Combination drop down. We know this is a bit intuitive and we will rename it so it is more intuitive.
